Problem with one front wheel not engaging into awd. Installed new armature plate, installed new magnetic coil, still not engaging. Outer seal sleeve is installed within .001, I even switch wires from right side to left side still not working... Getting very discussed Is there something I am missing.
Let's start with what year, what model, what engine size
Like "I have a '06 Sportsman 700" with AWD issues, cause different years have different setups and different models have different wiring and circuits.
did you check the coil and plate before closing it up....see if held the plate good....also get a meter and check to see if you have power to coil on the plug
Armature plate well be held when key is on. Tonight going to take good side bearing and hub
and put on side that's having the problem and see if will work. Trying to find out if bearing or hub
is the problem. Thanks for the input.
I was gonna suggest tranny switch buit if you crossed wires from working side and it still didn't work , that's not it, did you inspect hilliard clutch? do rollers move freely , is spring around them ok?Are you sure you got the outer sleeve close enough?Try using a block of wood and moving it closer.
Just put a new u joint in axle. Didnt have time last night to work on problem.
Going to check hillard clutch out again. But i think my problem might be with the clutch or hub, going to take other side apart and install on side not working and see if it will engage. Then switch one part at a time to see witch is bad.
thanks everyone for your advise will let you know what i find out...
113.2K members
