front hub / A-Arm removal - Page 2 - Polaris ATV Forum
post #11 of 17 (permalink) Old 07-21-2014, 05:20 PM Thread Starter
baitrunner's Avatar
Tried the bar and strap trick - no luck. PB blasted the snot out of it - will try again tomorrow. This forum is awesome. Thanks guys for your help!
baitrunner is offline
post #12 of 17 (permalink) Old 07-21-2014, 05:44 PM
mark02's Avatar
Did you remove the roll pin from the inner yoke?
mark02 is offline
post #13 of 17 (permalink) Old 07-22-2014, 02:47 AM Thread Starter
baitrunner's Avatar
no, didn't know it had to be removed - i can see the backside of the pin (round pin with square in center) how does it come out? Also, shouldn't i be able to rotate the shaft (unable to)? My axle looks like this (see image below) - so the shaft in the diff stays put and the yoke slides off the shaft?
post #14 of 17 (permalink) Old 07-22-2014, 03:51 AM
tomlang63's Avatar
I have a 2003 400 and my inner yoke is one piece, maybe they changed it in 04, but i would be surprised. Generally, on both front and rear, the diff has a receiver slot for the axles and the yokes come out when you pull the axle. Now if you have a roll pin, then punch that out and it will slide right off. Do you have the service manual for that machine? If not, there is a link on this site(sticky) where you can get them....
tomlang63 is offline
post #15 of 17 (permalink) Old 07-22-2014, 03:56 AM
tomlang63's Avatar
I stand corrected, I looked at the 400 parts manual for that year, and it appears that the yoke slides off after you remove that roll pin. Just punch it out with a hammer and a punch, and you should be all set.
Manuals found here:
Index of /ORV Manuals/Polaris/Sportsman
post #16 of 17 (permalink) Old 07-22-2014, 04:39 AM
mark02's Avatar
Your going to need a new pin most likely its going to brake whenever you punch it out. they are a Coiled Spring Pin. I think they are 3/16 you can order them from McMaster carr. McMaster-Carr
mark02 is offline
post #17 of 17 (permalink) Old 07-22-2014, 02:11 PM Thread Starter
baitrunner's Avatar
Red face
Ok guys, pin was a beast but, i got it out, axle removed! got some heavy duty cleaning to do while i'm waiting on the parts. you guys rock!!! if you're ever in the pittsburgh area give me a shout, beers on me!
front cv axle removal mbeal ATV New Members 8 12-29-2013 07:57 AM
Front box removal Jakedg Polaris ATV How-Tos 3 12-17-2013 07:10 PM
Front axle removal canuk ATV Repair and Maintenance 3 10-01-2013 11:39 AM
Front axle removal Hosstile Polaris Sportsman 4 07-18-2012 12:11 PM
Front CV Jpint Removal 87ttopstang ATV Repair and Maintenance 11 03-17-2012 10:56 AM
