2010 Sportsman 500- No Electrical Power - Polaris ATV Forum
post #1 of 3 (permalink) Old 12-11-2015, 07:24 AM Thread Starter
Dude89's Avatar
The other day my sportsman cut out. While driving it (was the fiance, not me), the display turned off and the four wheeler died, then started right back on it's own. Right now the display won't come on and it won't crank (unless jumped at the starter solenoid, cranks but no fire). The battery is good, connections are cleaned, all fuses are good, and the 3 wires coming off the solenoid all have 12V. Next step would be check the power at the display/ignition, but I don't know which wires at the display/ignition should have power. I need some advice in that direction.
I wired up a winch not that long ago, and used the orange/white wire for power to the solenoid for it. I believe that is the accessory wire, specifically there to provide power to something aftermarket only when the key is on. But is has no voltage with the key on. Obviously this wire would be after the ignition switch, and since it has no power, would suggest that the ignition likely doesn't have power either. Basically I hate electrical problems and any suggestions/advice is appreciated lol
Dude89 is offline
post #2 of 3 (permalink) Old 12-11-2015, 12:39 PM
4getful2's Avatar
Those have had issues with chafed wires along the steering stem. You'll need to remove the wiring from the conduit and look for some broken or rubbed raw wires.
Any blown fuses? Power point have any juice to it?
'08 Sportsman 500HO efi
'14 RZR 800 trail
'03 sportsman 500HO (gone)
'14 Massimo 800
'08 Hisun 700(gone)
'02 expedition 425(gone, but missed)
'98 Sport 400 (gone)
4getful2 is offline
post #3 of 3 (permalink) Old 12-13-2015, 04:58 PM Thread Starter
Dude89's Avatar
You were right, the power wire to the ignition switch was broke. Spliced it back together and away she went. Thanks!
Dude89 is offline
2001 Sportsman 500 Part Out corey237 ATV Parts for Sale 14 05-08-2016 06:57 AM
01 sportsman 500 ho oil change Polaris4you Polaris Sportsman 10 12-09-2015 06:11 PM
08 Sportsman 500 Harness testing HELP hunte567 ATV Repair and Maintenance 1 12-07-2015 08:01 PM
Sportsman 500 ho dash cluster problem hunte567 ATV Repair and Maintenance 0 12-05-2015 05:50 PM
