2006 Polaris Sportsman 800 starts/runs fine for few minutes then runs like crap - Polaris ATV Forum
post #1 of 13 (permalink) Old 04-10-2016, 04:53 PM Thread Starter
badzj999's Avatar
I have a 2006 Polaris Sportsman 800 and just got back from a weekend trip to Hatfield McCoy trails in WV. At the end of the second day of riding the Polaris started acting strange. It would start fine and run fine for a minute or two then slowly it would start to struggle to keep speed and after another minute or two it would struggle to do over 15-20 mph. If i stopped and turned the engine off and then restart the engine it would run fine again for another minute or two and then same thing would happen it would lose power until it could barely move itself and i would repeat the process again. Has anyone had experience with this before? I'm not sure where to start with diagnosing this.
badzj999 is offline
post #2 of 13 (permalink) Old 04-10-2016, 06:15 PM
mvn
mvn's Avatar
Just throwing it out there but could it be a pinched/blocked fuel tank vent line? I'm sure more ideas will be posted.
Mark
2012 850HO Touring EPS Pearl White
27" ITP Blackwater Evolution radials on 14" ITP Black Ops wheels
Ricochet skid plates & A-arm guards
Rubberdown 1 1/2" lift
Cecco frame braces
JC Capri bushings
Rotopax fuel packs on custom mounts
Garmin 60CSx with Ram mount
Polaris 2500# winch with synthetic rope
Polaris front & rear brush guards
Polaris bar & thumb heaters
Polaris passenger grip heaters
NGK (6043) ILZKAR7A10 plugs
Good, fast, cheap.....pick 2!
mvn is offline
post #3 of 13 (permalink) Old 04-11-2016, 04:06 AM
Yeah, check the vent. Sounds more like it could be the fuel filter plugged up or the pump and/or tank strainer shot. Some have found the pump strainer deteriorated and falling apart. A good start would be to check fuel pressure when it does that. It should be around 39 psi +/- 2 lbs.
If you eliminate fuel as a cause, check the wiring harnesses to the TPS and TBAP and TPS voltage. But problems there should be present at start too rather than coming on a few minutes after startup.
The only other thing I can think of right now would be an ECU problem.
polman500 is offline
post #4 of 13 (permalink) Old 04-11-2016, 04:25 AM Thread Starter
badzj999's Avatar
I am assuming the same that any plugged up vent line, fuel line or fuel pressure issue would be present at start up and not take a few minutes to appear.
badzj999 is offline
post #5 of 13 (permalink) Old 04-11-2016, 04:39 AM
Trip's Avatar
Mine did this at one time.
tbap sensor.
2012 Sportsman 800
-Engine
-4 Tires
Trip is offline
post #6 of 13 (permalink) Old 04-11-2016, 08:59 AM
Not really. A plugged vent would take few minutes of running to case a problem when a vacuum builds in the tank. Likewise, a plugged fuel filter or tank screen will often drop its load of crude when the machine is turned off relieving the pressure sucking it into the filter or screen. Had a 2012 Honda Foreman doing that and it took a little detective work to figure it out. Found out that Honda upgraded the filter configuration mid year to prevent that very problem. Same for the fuel pump. They usually don't mess up until it has run a little while and the pump overheats.
But it may very well be something like a bad TBAP. The only way to find out is to start testing and trying to eliminating the usual suspects one at a time.
post #7 of 13 (permalink) Old 04-11-2016, 06:11 PM
CrimsonTideJosh's Avatar
Did you ever figure out what it was? Mine is doing the same thing.
CrimsonTideJosh is offline
post #8 of 13 (permalink) Old 04-14-2016, 02:43 PM
I just replaced the ECM. Which I was told the voltage regulator/rectifier was inside of that as well and it did NOT fix it. Still getting the battery light and sputtering. Any results on yours?
post #9 of 13 (permalink) Old 04-14-2016, 05:44 PM
mvn
mvn's Avatar
Is your voltage high or low? Is your stator ok?
Mark
Cecco frame braces
JC Capri bushings
mvn is offline
post #10 of 13 (permalink) Old 04-14-2016, 05:59 PM
Voltage at the battery is at 12.3 and stays there when revving. Goes up maybe .3 or .4, but not much. Stator seems to be fine.
Polaris 800 sportsman Farmer95 ATV General Discussion 11 04-03-2016 05:45 PM
2006 Polaris sportsman 500 Starter spinning crazykyle12 ATV Repair and Maintenance 7 03-23-2016 09:57 AM
2007 sportsman 800 runs then dies? bwintz Polaris Sportsman 3 03-03-2016 10:32 AM
PROBLEM: Polaris 2006 Sportsman 800EFI Cranking problems gagobbler ATV Repair and Maintenance 1 12-14-2015 03:32 PM
