325 trail boss will not run with air cleaner on - Polaris ATV Forum
Polaris Trail Boss Discussions for the Polaris Trail Boss
post #1 of 6 (permalink) Old 06-17-2019, 04:36 PM Thread Starter
john1948's Avatar
2000 325 trail boss will not run with the the air cleaner on or the air top on without a filter. there is also oil coming into air box from the breather tube. It will run without the filter or the box top off.
john1948 is offline
post #2 of 6 (permalink) Old 06-17-2019, 06:27 PM
stave7119's Avatar
So the problem is too much fuel. Assuming that your air filter isn't plugged and the air box lid doesn't have any restrictions, I am betting that you can fix the problem with a carb rebuild. Good chance that the needle valve is leaking so it is always trying to empty the fuel tank into the carb. Makes it run really rich so with the air filter and air box together it can't get enough air.
Hers: 2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. QSC Clutch Kit, Hand Warmers
2001 Magnum 325 Warn winch and Moose 60" plow
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #3 of 6 (permalink) Old 06-18-2019, 05:20 AM
Did this happen suddenly - during a ride, or ran one day but not the next?
If it will idle, but not accelerate, then the carb needs to come off - might be as simple as the main jet fell out of the holder.
latebird is offline
post #4 of 6 (permalink) Old 06-18-2019, 10:45 AM Thread Starter
john1948's Avatar
the bike was sitting for 3 years. Started it and it ran but poorly, found oil in the air box and on the air filter from breather pipe. Now it will run without the air filter or cover, put the cover on with no filter and it stalls. Thanks for any help.
john1948 is offline
post #5 of 6 (permalink) Old 06-18-2019, 11:49 AM
Let's presume the gas was left turned on - so the engine is full of gasoline - if you haven't already changed the oil get ready to and get a large drain pan - drain the oil out, see how thin it might be and if it smells like gas. Install a new filter, put two quarts of oil in the engine, start it and let iT idle a minute, shut it off and wait about 30 seconds to check the oil (while you are waiting, take the dipstick out and wipe it off, the dipstick has to be screwed in when checking the oil) - if it's not screwed in it will be over full.
Might be the crankcase is full of gas and when you are trying to run it the gas vapor is being sucked into the intake through the crankcase vent hose - that would also explain the oil on the air filter
latebird is offline
post #6 of 6 (permalink) Old 06-20-2019, 04:05 PM Thread Starter
john1948's Avatar
thanks all, I did look at the one in question and there was a pool of gas underneath, thanks again and I will let you know when I get into it
john1948 is offline
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Trail Boss
