2015 850 Touring transmission - Polaris ATV Forum
 1Likes
post #1 of 14 (permalink) Old 03-11-2019, 05:14 PM Thread Starter
Marcellm's Avatar
New owner of 2015 850 sp touring with 600 miles. Iíve gone through most of the machine (all fluids, air filter, chassis lube ) to get ready to ride, but have a question about drive engagement. When sitting still, the machine clunks (especially in reverse) when the transmission engages. Seems ok while moving but the clunk engagement from stand still seems harder than I would expect. Anyone have insight???
Marcellm is offline
post #2 of 14 (permalink) Old 03-11-2019, 06:08 PM
Check for play in the propeller shafts front and rear. They will have some play but make sure nothing is loose.
On a side note, the Polaris parts catalog doesn't even include the prop shafts for your machine in the parts diagrams unless they them hidden somewhere that I couldn't find lol.
polman500 is online now
post #3 of 14 (permalink) Old 03-11-2019, 07:40 PM Thread Starter
Marcellm's Avatar
Thanks Polman. Doesnít seem like driveline.... it feels like transmission isnít engaging until rpm picks up more than Han expected. I can rev up and down a little with no engagement. So I always try to ease into it to slowly launch, but I get hard engagement.
Marcellm is offline
post #4 of 14 (permalink) Old 03-11-2019, 08:31 PM
You may need to clean and service your clutches and replace the belt if the engagement has become more harsh.
Polaris recommends to clean, inspect at 1000 miles/100 hrs and replace any worn parts as needed... more often with hard use.
I think some year models of the 850's were known for sorta harsh engagement. You might contact Ryan at RVS and see what he says about a clutch kit to smooth out the engagement.
post #5 of 14 (permalink) Old 03-12-2019, 03:51 AM
bp405's Avatar
What RPM does the clutch engage??
2011 Sportsmanģ 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsmanģ 570-T
2019 Alumaģ A8818
bp405 is offline
post #6 of 14 (permalink) Old 03-12-2019, 06:23 AM
You are not supposed to shift gears or ranges while in motion - you might just turn the idle down a bit, but if the clunk is not severe, it's not abnormal.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #7 of 14 (permalink) Old 03-12-2019, 10:50 AM Thread Starter
Marcellm's Avatar
Thanks for feedback everyone. It isn't when I shift gears. Its after I put it in gear (forward or reverse) that I can rev engine slightly before any engagement...then clunk! engage and off I go. Seems harsh, but reading more about this being typical. I'll record RPM at engagement tonight if I can get to the garage (work...and kids soccer...and....)
Marcellm is offline
post #8 of 14 (permalink) Old 03-12-2019, 11:23 AM
Yep - service the clutches
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
latebird is offline
post #9 of 14 (permalink) Old 03-12-2019, 11:42 AM
Another thing that will cause harsh or abrupt clutch engagement is not allowing the machine to warm up properly before taking off. You're supposed to let the machine warm up about 5 minutes to warm the belt and clutches and everything else. My 18 1k has about the smoothest clutch engagement of any Polaris I've ever been on...BUT, if I just hop on it cold, start it up and take off immediately it too will hesitate to engage and then hit pretty hard when it does. Not good for the machine or your belt and clutches.
I'm not accusing you of bad riding habits lol. I just know I'm sometimes guilty of being in a hurry to get on the trail or get off the trailer or get out of the garage and take off cold. Its just better practice and easier on machinery to get in a habit of starting the machine FIRST and THEN get yourself ready to go. By the time you get your gloves, jacket, helmet and whatever else put on, the machine has sufficient time to warm. Proper warmup will almost ALWAYS make for a smoother initial take off.
I'm getting long winded here, but another thing I do is to very seldom take my machine out of gear when I stop to take a break while out riding unless I'll be parked for a very long time. I know many will disagree, but I've worked on a lot of Polaris machines over the years with worn out shifter parts. I figure that like most other mechanical things, that mechanism only has a finite number of times its gonna operate from new until its worn out and don't work very well or needs replaced. On the newer machines you MUST hold the brake to start anyway. So unless I'm parked somewhere that I NEED to have the tranny in Park (rare), I just shut off in gear and start back up in gear rather than having to shift two times unnecessarily causing more wear.
post #10 of 14 (permalink) Old 03-12-2019, 07:06 PM Thread Starter
Marcellm's Avatar
Good points about warming up and shifter....Iím good about warming up before riding. So I went out tonight to check rpm. It runs up to about 1850-1900 before it engages. Funny but tonight very smooth. ??? I also tried a light rev and back off a couple times and got nice smooth engagement. Iím probably going to pull the cover and take a look at the belt.
Marcellm is offline
Over voltage Keith338 ATV Repair and Maintenance 31 06-06-2019 07:52 AM
Top end crankcase Masterbreaker101 ATV Repair and Maintenance 3 11-30-2018 11:59 AM
