squealing noise - Page 2 - Polaris ATV Forum
post #11 of 22 (permalink) Old 05-08-2013, 05:06 PM
Diesel73's Avatar
I would pull the belt and give the clutch a once over with a green kitchen scrubber. from the outside to the center not in a swirl or side to side. then rinse with contact cleaner or brake cleaner.... something that won't leave a residue.
1980 Honda 110 ATC - Retired
1988 Honda 250X - Sold
1998 Honda 250 EX - Sold
1998 Cannondale Speed 440 - Sold
2009 Polaris 850XP - Traded
2013 Polaris 850XP - Current
Diesel73 is offline
post #12 of 22 (permalink) Old 05-08-2013, 05:52 PM
InRBigness's Avatar
Take some emery cloth and scuff/sand out the sides of the belt and then scuff up the sheaves of the clutches. You don't need a new belt, you just need the rubber to touch the clutches without the glaze. Use low gear if you are in technical stuff or pulling weight.
08 Sportsman 500HO
01 500HO Plow Machine
InRBigness is offline
post #13 of 22 (permalink) Old 05-08-2013, 07:07 PM Thread Starter
shiflett104's Avatar
Sweet! i didnt think i needed a belt after looking at it, its not slipping when i drive it just sounds really bad. i will try the scuffing idea tomorrow and let you guys know how i made out. THANKS!
2012 Sportsman 550 EFI, EPS
shiflett104 is offline
post #14 of 22 (permalink) Old 05-08-2013, 09:19 PM
Rooskey's Avatar
Cant tell by that pic. The belt wears on the sides. Not top or bottom like serpentine belts. Take it off, if it has a blue to purple glaze on the sides of it then its toast. I bought a used atv and after changing the belt it is totally back to new.
2018 Sportsman 850 SP Camouflage
2014 Sportsman 90 Sage Green
2018 Honda 250 Recon
Rooskey is offline
post #15 of 22 (permalink) Old 06-16-2015, 07:14 AM
Matt358's Avatar
My just started to make noise today when I accelerate. I also never use l even on hills should I be but I don't notice my atv needs low. Atv 2010 850xp sportsman
Matt358 is offline
post #16 of 22 (permalink) Old 06-16-2015, 08:00 AM
the_transporter's Avatar
Also, if you take the belt off check which way it is rotating and put it back on so its rotating the same direction. Don't flip it.
2015 Sportsman 850 SP Titanium Matte Metallic
the_transporter is offline
post #17 of 22 (permalink) Old 03-22-2017, 07:02 AM
brandons103's Avatar
Did you ever find out what this was? I have a 2016 570 that that just started doing the same thing! Luckily I came across your video.
brandons103 is offline
post #18 of 22 (permalink) Old 03-22-2017, 09:28 AM
Battle_Design's Avatar
^ totally different motor and driveline.
850 XP
Battle_Design is offline
post #19 of 22 (permalink) Old 03-22-2017, 09:40 AM
@Battle_Design: Interesting. I am hearing the EXACT same sound as heard in the original post [youtube video]. Both are belt driven I assume? Could be the issue?
post #20 of 22 (permalink) Old 03-25-2017, 12:27 PM
jehar46's Avatar
Good luck been trying to figure this out since 2013!
https://www.polarisatvforums.com/foru...ion-550-a.html
jehar46 is offline
Belt Squealing Going Downhill?? Citrus Polaris Sportsman 9 03-28-2013 11:19 AM
2011 Sportsman 800 EFI Engine Squealing juslikedowntown ATV New Members 12 03-07-2013 05:58 AM
Fan noise, please help! PoPo85 ATV Repair and Maintenance 0 03-27-2012 03:43 PM
2006 Ranger 500 Squealing in High Gear Nurseryman ATV Repair and Maintenance 0 10-16-2011 05:41 PM
TB 330 Chain noise + brake noise bob330 ATV Repair and Maintenance 1 04-20-2009 02:08 PM
