1 - 2 of 2 Posts
hey guys new to atv's so please help. is there anything else i should do besides washing off the mudd after riding in the mudd all day. thanks :bsflag::nada:
Once it is clean - go riding again. If you use a pressure washer don't get the nozzle too close as you will force water past some of your seals. Keep the nozzle one to two foot away. Using a home water hose is safer for the seals but takes a little longer. Also keep the greese zerks filled with fresh greese, power washers will force water into these areas also.
1 - 2 of 2 Posts
