1 - 12 of 12 Posts
I have a 2000 Sportsman 325 4x4
Yesterday while riding it got stuck in forward low....cant get it in neutral....any tricks, tips....
Never happened before
Thanks in advance
You probably have wear in the shifter box or the linkage needs adjusted. You can usually rock the machine while wiggling the shifter and get them out. If that don't work remove the linkage from the tranny bell crank and see if it will shift to N. Then get the shifter in N and adjust the linkage rod so it easily inserts back in the bell crank.
will it shift freely when the machine isn't running?
well like polman said time to chk/adjust that linkage and hope you don't have to pull and crack the case.
Plastic parts get worn in the gear selector. They also sometimes get water in them and there is supposed to be a couple ounces of oil in it.
there you go!!!!!!!! clean er' up and grease er'!!!! happy trails again!!
Oh no sh!t oil!?!?!? Not grease, wow!!! What is there a fill hole for the oil??
1 - 12 of 12 Posts
