Hi, I'm new to the forum and I'm looking for some help.
I have a 01 sportsman 400, First off it would run ok only at full choke,and with it at no choke it would just die when I hit the throttle, So I cleaned out the carb and jets and now it only has spark the first split second when I start it and nothing else. I checked the crank sensor and its good. Is there something I'm missing?
Welcome to the board!
Discussion Starter · #4 ·
Yes I did clean the fly wheel and the crank sensor is getting/ giving the correct signal, just can not figure out just out of nowhere it just stop giving out spark. Does anyone know what to check on the little CDI box what the ohms or voltage should be?
Is the coil wire suppose to be ground and the resistance between the spark plug wire and the coil 10.6 ohms? also where the little coil wire wire goes and the spark plug wire the ohms is 10.6
