1 - 1 of 1 Posts
Hi, I picked up a 2001 Magnum 500 with a bad cam. When I went to repalce the cam I found that the piston and rings were shot, the piston pin seized in the rod and was scraping front and rear. I was going to do the piston, ect, but now I am wondering if the rod is shot too maybe I should try and pick-up a used motor, what do you think?
Also wondering what motors will fit this quad Looks like All the 2001 and later sportsmans would fit, but I'm not sure if they would work with my Carb, Stator, stator cover and if the primary clutch mounts the same. Anbody have any specifics?
Thanks for the help,
John
1 - 1 of 1 Posts
