When I switch the ignition on the guages don't illuminate, the lights won't come on, the neutral light does not come on, and it will not turn turn over. When switched on I can hear the solenoid click on and it did turn over a few times. I was told that the "Run" switch assembly on the left side handlebar is most likely bad and will need to be replaced. Does this sound correct? Any help would be appreciated.
OK just got it back from Polaris. It was a combination of the "Run" switch assembly on the left handlebar and the CDI unit were both bad. Total cost of repair + labor = $650.00.
