1 - 2 of 2 Posts
Hey guys, I have a 01 scrambler 500 with a blown trans. I purchased one off a 98,installed it then figured out that there is no gear selector switch on the trans of the 98. In 98 Polaris put them on the gear shifter? Anyone know if I can make this work? Thanks
you need to get in touch with whoever you bought the trans.from and see if they still have the connector for the switch so the wires will stay plugged in. wiring up the switch should be the easy part
1 - 2 of 2 Posts
