1 - 16 of 16 Posts
i watched as i tried starting the atv and the bolts got red hot and so hot they melted off the battery terminals..i checked both pos and neg wires for bad connections or wear/tear but could not find any issues. not sure where or what to do or check next and cant afford to bring it to a shop..any help would be greatly apriecaited, ty
starter may be bad, shorting out and pulling to much current
I agree that the starter is shorted out. As long as no battery wires are shorting out. thanks
I'd check the solenoid first. If it is shorting out inside it'll be a big short too. Plus it's easier and cheaper to replace if needed.
where is this located and who do i check to c if its gd or not ? solenoid ..thanx
It is on the left side of the battery box. The + positive battery cable goes to it. I still think it's your starter. Let me ask you this when you let off the start button does the starter stay engaged. thanks
no it acually struggles to get the starter started if that makes sence..like a weak battery and screeches abit
I agree starter is drawing way too much voltage and frying the cables.....Muddie49
I agree, Bushing in the starter is binding and the starter motor is drawing too much current.
Discussion Starter #11
ok so i tried a new battery and same issue..i fixed the re-coil to use the pull start untill i can afford a new starter but it is so hard to pull at a sticking point that it accually hurt my fingers..would this all be related or a diffrent issue ? found some starters on ebay cheap anyone have any experiences with these ? also does the bendex need to brem replaced also ? still havnt found a diagram on how to take started off since i read somewhere the bolts are hard to find,ty
Some auto parts stores like Napa and Auto Zone will check auto starters for free. I would assume that they could hook up and check an ATV starter to see what kind of pull it takes to get it going.
Discussion Starter #13
how do i get it out with-out specail tools to remove clutch ect . ? anybody know ?
The best place to buy a starter and drive is www.dbelectricial.com you can get both for around $86.00 . The bolts are behind the belt cover. I have a wrench that has been grinded down to fit in the tight space. A ratchet wrench would probally be better but I used what I had. Once the bolts are out rotate the starter and it will come out. Thanks
Discussion Starter #15
TYVM..and if anyone has a daigram of this area or a lnk too much appreicaited...
1 - 16 of 16 Posts
