1 - 1 of 1 Posts
So the fun never ends around here...I just get it to run well enough to use it and now I have a clicking noise from the front right hub.I tried pushing it in neutral and it feels like it binds and then clicks and then lets go,another 10 feet and repeat...I had t apart when I did the lower ball joints not to long ago so I thought maybe I put it back together wrong,tore it down tonight and reassembled,cant find any broken parts,plates bearings,ect.There IS a small amount of tiny metal shavings on the drain plug magnet,do you guys think I screwed up a bearing.This issue just popped up didnt start immediately after the BJ work.Does anyone know the bearing number for the 4 in the hub?Are they all the same?Thanx in advance for any advice you can give me!BTW 2wd,4wd has no effect on the issue.
1 - 1 of 1 Posts
