Looking for a video or pics or step by step on how to change the oil and trans fluids on the 01 Trailblazer
Isn't your engine a 2-stroke? No oil to drain from the crankcase. The tranny has a drain plug and you pull the dipstick and add fluid there. You can look up your quad and see the exploded diagrams here.....
Browse
Yes 2 stroke, I'm a newb so not sure what to do. I want to get it ready all I have left is to change fluids....
Trailblazers have a two stroke oil reservoir under the front plastic. You fill through the capped hole thats on top of the plastic. Fill with the two stroke oil which is different than engine oil. It automatically mixes with the gas. There is no engine oil. Make sure you fill it with two stroke oil. It should last many tanks of gas
