Ok guys, it's rare I get stumped, but I've been through about everything and still stuck on this one. Probably over thinking it. Got an 02 700 in the shop. Starts right up, idles perfect. throttle response in neutral is good. Go to drive it and anything over 1/4-1/3 throttle does nothing more than make more noise. Will top out at about 35-40 in high gear in about 6 blocks.
Things done so far:
Cleaned carb, checked jetting, diaphragm on slide, choke, ETC, carb boot, air and fuel filters. Tried a different fuel pump. All good
Replaced plugs, ohmed out caps, plug wires and coil. Ohmed out stator. All good.
Replaced worn bushings in primary and secondary clutch and washers next to one-way bearing. All working good there now.
Removed exhaust and checked for obstructions. All clear.
Only issue I've found is it is over charging a bit over 1/3 throttle. Getting about 16-16.5v out of it. But that shouldn't make it run like this. Seems to be fuel or air related, but everything checks out. Anyone have one do this before that can help?
Things done so far:
