1 - 2 of 2 Posts
I purchased this atv used and beat up. Has never had operational awd.
What I have done so far:
Speedometer never worked. I wired it so the magnets would always have power. I replaced one magnetic coil and it holds the armature plate very strong.
I put it back together torqued to specs and have power through the axle, armature plate, hillard clutch.
When all 4 tires are off the ground the hub turns but I can stop the rotation with my hand if I try with some force. Feels like it is grabbing but not "locking"
So for grins, I took out the outer bearing that sits inside the strut. I put everything back together and the front hub locked in. What does that mean? (I want it to operate with all the bearings though)
So any suggestions what I should look at now?
Welcome to the board!
1 - 2 of 2 Posts
