Hello all....before i go and tear something up, just wondering if anyone has any pointers. My reverse indicator light comes on in reverse, and in low or high...goes off in neutral (neutral light come on as its suppose to). I checked all the linkages and they are fine, shifts into all gears easily. Im pretty sure it is a switch issue...and i think its the back one (has 2 on top of the trans)...I have not taken it out yet but wondering if there is an adjustment, or anything else to look for???
Correct, it is the rear switch. You could try removing it and see if it needs cleaning, but most likely time for a new switch.
