1 - 2 of 2 Posts
Can anyone tell me which end of the rear axle is which? Is there an inside and outside...which end goes towards the transmission..and or which end goes towards the wheel...?
I just rebuilt both sides, and one of the axles pulls out of the trans slightly once I tighten the castle nut, causing the race/bearing assembly to pull out of the trans as well. All is good and turns freely until I tighten the castle nut, then the race pulls out of the trans causing it to bind.
If you got it in the trans that is the right way. It will only fit one way. Is the snap ring on the splines in good shape? If not they won't hold the splines into the diff. You just may need to get a new snap ring put on the inboard cup and see if that helps.
1 - 2 of 2 Posts
