My 2002 Sportsman 500 H.O. Has oil on the rope of the Recoil Starter before I tear into it seeking info I guess there is some kind of seal that is leaking, How difficult to repair?
Yes you do have a seal leaking.You'll need to remove the rope cover, flywheel, you'll most likely need a puller for that, remove the stator plate, then seal should be right there.
