Bought this quad last fall and re-done all the wheel bearings and bushings, new primary and secondary clutches, new struts, new carb boot, new fuel pump, carb kit, and new coil. It probably has high miles, it seems like it should have more power. I have a 98 500 sportsman and I'm pretty sure it has more balls. Any idea what might be my problem? It runs fine(aside from a coolant leak I have now), it just doesn't have the power that I feel it should.
Any help would be greatly appreciated.
hows the compression ????
Valve's may need to be adjusted. You mentioned a coolant leak. Is it leaking on to the ground or could it be a blown head gasket?
Discussion Starter · #6 ·
The primary and secondary are brand new and came already together so I just installed them. Are you thinking I need to tighten the secondary?
The 'bad' years for exhaust cams were about 96-99, they had it right by the 02s. What is the top speed of ur 98 vs this 02? My 98 will hit 50+ where as my '10 will hit almost 60 but I back off cuz of the squirrely feeling in dirt roads...haha... :banana:
Discussion Starter · #9 ·
I can't really compare the speeds cause my 98 has 27s and the 02 stock tires. The 02 just seems to fall flat tight away. I put 2 new clutches on but used the old primary spring. I'm not sure if a pooched spring would cause the effects I'm feeling.
