I’ve see this discussion all over the internet and haven’t gotten a clear answer. My Speedo doesn’t work. It blinks, I have hour readings but not movement. Can anyone help?
The system needs to be tested and the corrective action taken - might be a connection, just a bad battery, a failed rec/reg or stator or combination of faults.
I sell batteries - new batteries can be bad right out of the box
Start with having the battery tested - if the battery passes muster, then get the multimeter out and start with simple voltage checks. I'll guide you through them once the battery is known to be good.
