1 - 1 of 1 Posts
seems to be one problems after another with this quad but im working my way though them and its getting better and better.
Previously ive had absolutely no issues with the fuel pump, its always worked well. however, I recently removed the carb and gave it a good clean out (which was well overdue), put everything back together and went for a quick 15min shake down run on a bit of rocky ground near my house. when I returned to my house the strong smell of petrol followed me and after sitting on the drive way for a minute a small puddle had formed on the ground under the fuel pump. I shut the quad down and dried everything up, started the quad again and immediately small amounts of fuel are spraying out of the vent hole(?) on the back of the fuel pump.
at the moment I cant get hold of a pup rebuild kit or a new pump im just wondering what could be causing it and could it be easily fixed? enough fuel is reaching the carb and the quad still runs well...just not happy with having a fuel leak.
1 - 1 of 1 Posts
