I Rebuilt the carb and installed new jets. When I put the carb back on the bike, it only runs with the Choke pulled out. it dies the second I barely push the Choke in. Other symptoms include backfiring, exhaust and intake popping with flame. So far the things I have checked or tinkered with include:
- Making sure the Choke cable is routed correctly
- Correct Jets and cleaned Starter Jet
- Turned the Fuel Mixture Screw 2.5 and also tried 3.0 turns
- Adjusted the Idle and Throttle cable
- Cleaned and even replaced the Jet Needle
- The Float "Seems" ok
Please help if you know Useful information to help me, Thank You!
