noticed the other day that the rt frt wheel isnt turning when in awd replaced bad armature plate and saw some sm scoring on the backside of the hillard clutch took clutch from other side and still didnt turn. turn on awd switch and plate sticks to magnet dont know how strong the pull is yet though. any thoughts? pull from magnet dosent seem that great can slide it to the side easily hope im on right track
If magnet is right you have to work pretty hard to pull plate off, try tapping the seal sleeve in farther before you buy a magnet , gap is .00o to .001 so they are in pretty tight. use a block of wood to move it in so you don't damage it
