Recently picked up a 1000 mile 03 Sportsman 600 from my FIL. It would run but fall apart at partial throttle backfiring out the exhaust. He took it in for service shortly before I purchased it, and they found one fouled spark plug. I then got it and it still would fall apart and backfire. I dug into it and found a cut in the rubber boot from carb to head but not though, and a chunk of something in the bowl. Replaced the boot and cleaned the carb, and inspected the diaphram.
It now starts great, however the exhaust at idle smells super rich. Immediately after going through the carb, puttering around the yard it was ok thought i didn't have a problem and now after sitting for a week it again falls apart just giving it gas and during partial throttle till you get going a little faster then it seems ok. If it's super warmed up it doesn't seem like there is a problem. I haven't pulled the plugs yet.
I was thinking ignition related but as I type this I'm wondering if the float is partially sunk. (I don't notice fuel coming back into the air box.) I'm also thinking I could try to tweak with the idle air screw but after that I'm out of ideas. I'm not terribly knowledgeable on slide valves so if there is something else to look at let me know.
Anyone else have thoughts to what I should look at before dumping a ton of money into an ignition system. (it's the OE Ducati ignition that I've read were problematic.)
Nate
Nate
