Good day, been on this forum getting great info for a while, but first time login and post. I have done a ton of work on this ATV, replaced rear gear case bearings, removed and cleaned the carb, front end work and changed all leaking hoses air over the last couple years. Finally runs well, but now when I put a load on it, I have an oil leak draining from around the area of the oil fill tube, from behind the clutch cover area. Any ideas before I start to tear that apart. Thanks
Discussion Starter #2
I pulled the clutch cover off and the leak appears to be coming from the area where the oil fill tube goes into the engine. Is there a seal in there or can I tighten that down?
According to the parts breakdown, yes there is an o-ring seal in there.
Thanks, got it. The o-ring looks in good shape and the bolt was tight so not sure if that was the problem, but will get a new one and see how it goes. Thanks for the feedback.
