2003 Sportsman 700 wont go into 4x4 in forward. Plowed snow,stopped and then it did not work. Changed fluid, front differencial has power to it. Speedo and gear select work fine. Last year rear 4x4 intermitant in reverse. Is there a bypass or quick fix? Can you use a 2002 700 speedometer?
Welcome to the board!
check the plug right on the awd switch i had this problem and it was a dirty plug simple fix
