Hi Everyone,
I have an 03 600 Sportsman with about 960 miles on it. It has been garage kept and in great shape except for the fact I left the gas on and could not ride it over the summer. Fast forward to last weekend and I could not start it up unless I feathered the choke a lot. I got a rebuild kit and put in the new(supposedly the same jets as came on the bike) parts, tried to start it up and had fuel and a little oil come blasting out of the head into the air box return(smaller tube). I was not the one who took the carb out in the first place( I learned that lesson fast). I was hoping that someone could help me out and post a picture(s) of what tube goes where on the carb as far as the fuel line and such to help me figure out what happened. It is a OEM Mikuni carb. When I looked at it before stripping it down to remove the carb it looked like the fuel line from the pump(there is 4 lines from the pump) which had the heat shield wrapping on it went to the left side towards the bottom of the carb. Then there was the bowl drain from the bottom of the bowl which has a screw to remove water from the bowl(the tube was clear). There is/was another clear tube with a small radius curve in it that went I thought towards the top of the carb. I have looked at the service manual and it does not give or show this information clearly. If someone would be so kind as to help me with this info I would be so grateful! Also, In the service manual there was supposed to be information on how many turns out the needle valve and such are supposed to be backed out that I could not find. There was supposed to be an addendum page(s) with all the factory screw setting and such that I guess I am missing. Thanks for helping me in advance!
