1 - 8 of 8 Posts
hi I have an 03 predator 500, and I cant seem to get it to go into neutral when its running.
It goes in fine when its off.
and to top it off it goes into neutral quite often while Im riding it, and shifting from 1st to 2nd.
I don't think its related but I think I also have a problem with my one way clutch in the starter housing. because the starter turns but rarely does it turn the engine.
thanks for the help
Welcome to the board!:rockwoot:
well don't really have a solution but he isn't the only one mine does the same as far as the whole neutral thing.I think it's just the 03 model that does it.
Neutral is hard to find sometimes on the 1 down 4 up quads
i have an 03 and its a pain sometimes
and the starter barely starting the engine could be a bad RM Stator or you simply need a new battery
and it going into neutral while riding could be the clutch going bad and neutral is between 1st and 2nd gear so if you dont press up hard enough you will put it into neutral instead of putting it into second
thanks for the reply. I cant ever get it into neutral, at least while its running. Ive actually tried for 10-15min at a time. just sitting there shifting up and then down, up and then down. Ive had my friends try same thing.
ive just gave up on it. I keep a piece of tie wire on my handle bars and just tie the clutch down when I need to get off for a few min.
and the starter spins really strong, it just doesn't turn the engine. and when it does it makes all sorts of slapping banging sounds. from what Ive read im fairly certain its the one way clutch.
I just got the clutch in the mail and am waiting on the fly wheel puller tool to do the job. hope it works, fingers crossed.
i dont know what the starter turns to kick the engine on (maybe a gear) but maybe thats loose or not turning right
and good luck with your clutch
and how much is a new clutch for the 03's?
Discussion Starter #8
Its not the drive train clutch( the one that sends power to the wheels)
Its a clutch just for the starter. it goes in between the starter and flywheel so the starter can turn the engine, but the engine cant turn the starter.
thew clutch was about 170$ shipped and the puller was about 25$ at my local dealer.
1 - 8 of 8 Posts
