1 - 1 of 1 Posts
So I bought an 04 330 a few weeks ago with some problems. It needed a new caliper among other things. Found an 05 on ebay that looked identical. Went to install it tonight and would not work. Apparently the 05 uses a banjo bolt and 04 is a compression fit. Does anyone know if I could change out the brake lines to the banjo style? Guess I should have bit the bullet and paid for a new caliper from the stealership.
1 - 1 of 1 Posts
