I purchased a 04 400 sportsman. I have major play in the front differential. I ordered a bearing kit . This will replace the splines in the differential. 50% of my problem solved. Now I thought I'd order the stub shaft from polaris from the universal end to the differential. NOT that easy!! There is no part number for this. local Polaris dealer tells me I have to order the complete cv joint!! grrr. Has anyone come across this problem before? Much help would be appreciated. Thanks
Discussion Starter · #2 ·
Polaris front Diff
Well Well. The front bearing kit does not come with the inner spline. And apparently polaris does not make "just" the inner spline on the axle, male side. Anyone have any suggestions on where to buy the female spline for the diff and the male end on the cv joint. By the reading I've done, Polaris drive system wears out around 5000 miles.
Welcome to the board!:med:
