So we went out quading this weekend & did a little mudding & had something
interesting happening. When we hit some water the hot light & check eng
light would come on? I have a temp gauge & it wasnt overheating & the fan is working, cutting in && out normally.
It happens in even shallow water not into the rad. Happend every time we hit water? It would go out quickly or just turning the key off & on would turn of the lights as well? I havent had a chance to look it over so I thought I would ask if someone has a idea or had this happen. It dosent take much water not past the floor boards would do it.
Have you checked for any codes? It has too be a wire that's rubbed threw and grounding on the frame when it gets wet. I'd take a water hose and wet one area at a time till it shows up
Sent from my SCH-I545 using Tapatalk 2
Haven't checked for codes yet, that may help. I was thinking on using a garden hose on it to see if I can find it, I was just wondering if there is anything common as for wires that were about floor board level I should look at.
