Hello, I am in need of help.
I have an 04 sportsman 700 twin that is giving me a few issues.
First thing when I am using the lights it turns off. And now the
Speedo button wont work. I am not good with wiring. Look for the
Starting point to figuer this problem out.
Mike
Welcome to the board!
Sounds like a short or bad ground in the combination headlight/overide-speedo function/kill switch. Definitely a wiring type issue.
Battery is good. Fully charged. Im going to take a look at the switch. I do a lot of winter riding so water from melting snow may have found away in. I will post back once I see if there is anu issues inside.
Thanks for the help.
Start by making sure everything is grounded securely. A bad ground will cause all kinds of weird problems.
99% sure its a wiring, more specifically a grounding issue. Also check your zip ties that are holding your handlebar wires, they sometimes crack against the handlebars and ground out. Enjoy tracing the problem, segregate portions of your wire and work your way thru it, get the wiring diagram. I'm at work and cant look it up, but cheapcycle parts.com has many schematics. Just pay attention to your specific model#, as there are strange 1/2 year models made. Hope this points you in the right direction. Joe
