1 - 14 of 14 Posts
I've been having issues with my 700. Not sure what's going on. Will be running fine and just cut out while driving around, and wont start up for a while. I know when it will start because I can hear it cycle when I turn the key, and it wont start when i dont hear it cycle. Any ideas? Fuel pump? Wiring? Any feedback is greatly appreciated!
Bad key switch or the fuel pump is working intermittently. I'd lean toward key switch.
RMStator has the upgrade!!
I was under the impression we were talking about a 2003 700. If it's a 2004 it may or may not be the Ducati. They changed mid year.
Discussion Starter #10
I figured out it's an early 04, manufactured 2/20/04. But with it being an EFI, I'm having issues finding the right parts, everything is saying for carb only
If its efi look at 05 for parts.
Discussion Starter #13
Well I changed out fuel pump and key switch, and am still having the same issue! Very frustrating! Any ideas? Also getting codes 45 51 52
Sounds like the wires going to your T-BAP and both injectors are bad. Thoroughly inspect all the wiring going to those components.
1 - 14 of 14 Posts
