I havnt had tis machine very long, while riding in the snow i noticed my four wheel drive will not engage in reverse (even when over ride button is pushed), and when in 2wd it engages 4wd on its own after the rear tires spin a bit, is any of this normal? Or can it be chalked up to the cold?
If i need to replace the front diff, what other machines use the same one and can i switch it out for mine?
Welcome to the board!
I had this happen to my 2002 700 Sportsman. There is a brown wire that goes from the pod down the handlebars and under the front plastic. It broke from chaffing so i extended the wire and soldered it and shrink wrapped it. It may be a different color for your quad.
