Hello, and back with a new questions. Just replaced my CVT belt and wow does that make a difference! Great acceleration! Shifts SOOOO much easier. All good stuff.
However, noticed what looked to be a collar or some fitting that was just floating around the drive clutch shaft, see the image below. I thought this was a spacer or maybe a bearing cover, so I forced it back in the space between the shaft and drive clutch front housing. Seems to be running fine.
Can anybody confirm this part and should it be replaced?
Thanks in advance,
Ron
That looks like a bushing and yes, you should take it apart and replace it. Check cyclepartswarehouse dot com for cheap OEM parts.
bushing
Kevin,
Thanks for the reply. Will replace the bushing then.
Ron
