21 - 30 of 30 Posts
The belt looks a little tired. Pull it off and inspect it closely but also check the one-way bearing in the primary to see if it turns smooth by hand and is easy one way but not the other.
Did you have the tranny in gear or N when it was sitting still at idle. It won't turn in gear unless the machine is moving. Rev it up in N and see how it acts and if the belt is running centered in the primary or against one side or the other.
Discussion Starter #23
Thank you ! I will check it tomorrow. I decided beer sounded like a better plan since I was not winning tonight.
Discussion Starter #25
Will do! Thanks for all your help. I think the one way bearing is the culprit. Should I swap out the belt while it is apart too?
Hopefully I get the gear indicator corrected easily. I am thinking I mist be a tooth off if that is possible
Discussion Starter #26
Well.... I was able to correct the gear indication issue which was easy. My one way bearing goes both clockwise and counterclockwise so I am pretty sure that is toast. While I have it apart i am putting the clutch back to stock.
The belt does not look bad to me but I think I will take it with me when I bring this clutch in to get the bearing switched out. Do you think this could have been my problem the whole time (the one way bearing in primary clutch)?
Discussion Starter #27
Well I dropped the clutch off at the service dept at the dealer and they will put a new 1 way bearing in it this week and I also asked their recommendation for the belt. Hopefully by Thursday night it is all back together if I can get my clutch back Thursday
Nice, hope this solves all the issues. OEM belt is about the best there is. Gates also makes a very good belt for less $$$.
Discussion Starter #29
Me too! I want this back together. We have a trip planned to ride this Saturday. I am also hoping to sell it and get something a bit newer and I do not feel right selling something that is not working correctly.
Discussion Starter #30
Well I got the bearing replaced last week and was able to ride Saturday 40 or 50 miles without problems! Thanks for all your help ever3
21 - 30 of 30 Posts
