I have a 04 sportsman 500 h.o. while riding the other day noticed the battery light and spedo light were flashing so i shut the headlights off for 15-20 seconds gave it alittle gas and the lights went off and when i turn the lights back on the flashing lights come back on after about 20mins anyone else had this problem???
dose it start with the electric start?
you still should look at the battery ,make sure it's full of water and load test it as well.your's should be new enough that you can see how many volts it's charging thru the speedo.pod. check it with lights on &off. it may be overcharging
if you can get it to do the flashing light deal at home as soon as it starts having fits shut the motor off then turn the key to the on position and listen for any clicking sound(a bad circuit breaker)
