I just picked up an 04 Sportsman 600 and the fan isn't coming on far as I can tell, I've ran it for a bit and it did come on but I put a meter on plug and theres 14 volts there while running. Plug the fan in and it doesn't run. I hooked the fan direct to the battery and it ran fine. So I ended hooking it to a switch so I could use the bike but afer running the fan for a few minutes the fan starts getting a little noisy. So heres my questions.
How long should the bike be at an idle for before the fan comes on?
Is there a warning light before it over heats?
Why is there voltage at the plug but when you plug tha fan in it doesn't run?
Is there a way to grease the bearings in the fan?
Is there a cheaper replacement than a fan from a dealer?
