So when I bought my 04 sportsman 400 it had no headlight pod or guage on it it had been rolled and sat for a while. So I replaced what need to be bought a new guage and it worked great at first then it started to act funny at higher speeds 35 plus in high gear it would start to flicker shut off reset then come back on. I didnt know what it was maybe a bad ground so I started looking at the grounds and they all look good. Then I looked for a pinched wire in steering. Nothing. Winter came and I started using it to plow and it got worse. Now anytime over 3500 rpm it dose it and cuts 4wd. My light still work and it stays running. Any ideas
Ok so reading that I probly should have also mentioned that the run/light switch on the bars is probly going bad if I bump it it kills the bike. I was thinking that might be part of the problem. I ordered a new one so we will see
