When shifting from low to reverse some times the linkage gets stuck .It also seems like it is hard shifting from high to low ,just seems like it takes alot of effort to shift ??
its a 500 ho 2004
its a 500 ho 2004
I think this is whats going on .It acts like the clutch isn't disengaging and it does creep . Do these clutchs need cleaning once in awhile ???Another thing that causes hard shifting is when your drive belt is still turning at idle. Is your bike "creeping" a little? A sure sign it's your belt causing your tranny clutch to turn when it's easier to shift with the engine off. Take off your clutch cover and watch it when your running the engine at idle.
