1 - 2 of 2 Posts
changed oil in 05 500 dealer said i could drain block found out pinching hose after fact put oil in tank start it up atv runs ok did i do any damage by not priming pump
If you did not remove the oil hose at bottom of oil tank to clean metal screen then no. Priming oil pump is only necessary if the oil hoses are detached from oil tank causing air to get in hoses that oil pump can't remove.
1 - 2 of 2 Posts
