I have a 2005 sportsman 500HO AWD
I have two issues
1) the AWD does not work, the light does not come on the indicator on the dash does not show what gear it is in ( Replaced Gear Indicator relay still nothing) changed the front diff. fluid. It will work in AWD if you use the manuel override button .
2) the top center light will not work replaced the bulb nothing, noticed I have power on both contacts
Just purchased this unit said it had a new ECU and replaced the left handlebar switch which made the dash work.
Thanks for your help.
Steve
I have two issues
Steve
