I recently was given an 05 magnum 330. I replaced the whole wiring harness and the starter solenoid. I have no power. The speedo is obviously toast. My question is, does the speed HAVE to be working for me to be able to start or should I be checking other things? I cleaned the kill switch as I heard that is also a common problem. Thanks in advance
My is same way did you ever figure it out
Yes. The speedo does NOT have to be working. I ended up replacing the kill switch and then the starter and it fired right up. Speedo still doesn't work and seeing how that costs $280, I will just leave it that way.
