Im kinda puzzled my scramblers right hub will not engage? The magnet is getting power. I tested the magnetic strength with a screwdriver but it
does not seam to have much pull. Has anyone had this happen? How much strength should it have? I don't think its enough to pull the spacer. Any suggestions?
The magnet could be getting weak or the armature plate may be warped. When its energized it should be very hard to turn by hand. I have an 01 500HO that I had to replace the bottom end of the strut on for exactly that reason.
You could rebuild the magnet or replace it but that was almost as much money as replacing it. Mine came with new hub seals installed and a ball joint which was nice.
Yea I'm thinking the same thing but just wondering if anyone has had a similar problem because I just want to know what t look for.
