Got myself a new winter project. It didn't have spark when i got it found out it was a cdi. I had one laying around put it in & it runs like a champ. It sat for 4 years so i took the carb off & cleaned it first. After it ran for 5 min the fan cut in I felt rad hoses & they were both cool. I put in a thermostat hoping it would fix it but same thing.
I removed water pump cover & turned it over & the impeller isn't turning. I can turn it by hand & it sounds like something is turning inside. Checked service manual & found the shaft that drives the impeller comes from the oil pump!!! Engine wasn't making any noise. I know the engine has to come apart but has anyone come across this, & what was it?
Not very clear in the service manual what drives it, balance shaft or right of the crank.
Any thoughts?
Any thoughts?
