Got an 05 700 carb. machine, my daughter says she ride for a bit and itwill shut off, fires right back up, this happens pperiodically thru the day, thinking stator but also read about electrical connection issues. Also she called the other day and said while riding overheat light came on and pushed coolant out over over flow, fan is working Any ideas, thanx
You might want to try loosening your gas cap and see if it shuts of. My 500 did same thing and turned out to be the vent line was crushed and created a vacuum that would not let gas into the carb. It would die, then sit a sec while gas filled carb, started up and run until carb bowl was empty.
sportsman
Doesn't seem to be that issue, it doesn't happen consistently, by description it sounded electrical to me
