Hi All,
New member and new first time Polaris owner!
I recently bought this ATV and since I am new to them I missed these issues when I bought it. I have gone riding 3 times and it runs and drives great and has low miles for an 05 (780mi)
It started when I changed the oil and tried to enter diagnostic mode to reset the maintenance notification (flashing wrench). It will not enter diag mode. I started my research and find that if the ECU doesn't know you are in Neutral that it won't enter the mode. This led me to realize I didn't have shift indicator at all. They only light up for a second when I first turn the key on. Most people are also saying that in this condition the AWD won't work. I have jacked it up and find that all 4 wheels turn all the time no matter what the AWD switch is set to. I found a few more quirks and will list them here below along with what I have done so far. I noticed that there are lot of different grounds that pretty much end up in the same places but I could see how a bad ground in one area could lead to only a few things not working. I know the next thing to look at is the resistor module but then I'm thinking how would this effect the AWD, trip reset and diag mode. Anyhow that's why I am here!
Issues:
-No shift indicators at all
-Won't go into diag mode by holding the mode button while turning the key on when in Neutral (or any gear)
-Won't reset trip
-No AWD icon except when pushing the override button
-Always in AWD
What I have looked at:
-I removed the plug to the trans gear position switch. I used a jumper to connect the common wire to the other connectors to see if the display would show a gear and it does not. So I am thinking that the trans switch is ok.
-With all 4 wheels off ground AWD is always on no matter where the AWD switch is
I am not the best at electronics but not bad with some guidance. I have been looking at the schematics of the service manual and see how I might check the resistance of the resistor module but since I don't get a reading on the display with my jumper test I'm thinking there could be a continuity problem right off the bat or there is an issue with the Speedo or ECO possibly.
Here is what I was going to do next and I am not sure if I do it with key on or off or how I might damage it:
Disconnect 16 pin from speedo and test the resistance with a multimeter. I assume I would have the multimeter black lead on the pin that is the common that comes from the trans switch and the red lead on one of the connectors coming from resistor module. I am unsure if I need to do anything with the white wire though that also comes from the resistor module
If all looked good I was going to then plug that speedo connector back in and go to the ECM. There are some wires related that then go from the spedo over to the ECM but I am unsure how or what to check there.
I have a weird feeling that my problem is going to be more related to the Speedo module or main ECM than it is going to be from this resistor pack unless it is possible for the resistor module to short things out.
TIA guys!
Issues:
-Won't reset trip
-Always in AWD
TIA guys!
